June 10, 2004, 16:29 |
pls tell me the differance
please tell me the differance b/w contours and path-lines. thanks Muhammad zubair
June 11, 2004, 02:03 |
Re: pls tell me the differance
Assalam Alaykum wa Rahmatullah
We could generate contours of any thing like pressure, velocity or y+ while path lines are the lines traced by the points. Wasalam Mukkarum |
June 11, 2004, 04:31 |
Path lines are the path traced by the fluid particles during flow over bodies and inside the domain of your calculation. Contours gives the constant property lines,i.e., if you take a line in a temperature contour, it will give the same temperature on that line. Like that if you take any contours they will give constant propeties of particular property.
HELP PLS: Simplefoam manipulated to add diffusive mass transport...but solver stops!! | 1gn0rant | OpenFOAM Running, Solving & CFD | 1 | August 13, 2010 11:02 |
help me understand porous media in fluent~ pls pls.. :( | naftalena | FLUENT | 0 | February 28, 2010 12:20 |
i need help following problem pls pls help | gmani | CFX | 4 | March 31, 2009 09:39 |
gambit "pls help me" | chandra sekhar b | Main CFD Forum | 1 | November 17, 2008 11:47 |
multi phase flows....pls help... | karthik | FLUENT | 0 | November 16, 2005 09:15 |
