Import ICEM Mesh to Fluent
Old   June 18, 2004, 01:50
Default Import ICEM Mesh to Fluent
Fluent Beginner
I used ICEM for a long time but I am new to Gambit and Fluent. I just wonder how I can import the mesh generate by ICEM into Fluent 6. By the way, I generated the mesh using ICEM on Windows system while Fluent 6 is running on IBM AIX system. Is it possible to import the mesh into Fluent?
Thanks,
Fluent Beginner
Old   June 18, 2004, 08:37
Default Re: Import ICEM Mesh to Fluent
Bob
Yes it is. When you open Fluent just open the mesh file and it will open in Fluent. This is how I open mesh files created in Gambit.
Old   June 18, 2004, 13:12
Fluent Beginner
Thanks Bob. But I am still not sure how to import the mesh into Fluent. Follow is the operation I conducted:
1. Start Fluent located on AIX system by SSH from Linux system:
ssh userid@server
2. Click File->Import in Fluent program
But I can not find ICEM option. We have ANSYS, CGNS, FIDAP, GAMBIT, IDEAS, Nastran, Patran, Fluent 4 Case, PreBFC, Partition.
Could you please explain it in more detail?
THanks,
Fluent Beginner
Old   June 20, 2004, 01:05
Bob
You don't go to file-> import. You go start to the file-> open. Open the mesh file as if you were opening a regular fluent case file.
Old   June 21, 2004, 00:13
Fluent Beginner
Thanks, Bob.
Old   June 23, 2004, 00:27
jyothishkumar
Dear fluent beginner,
I have seen ur id from cfd online website. I am working in gas turbine combustor. I am using gambit as my preprocessor. my geometry consists of many holes(dome holes(670 in no.,flare holes(790 in no.) etc) Meshing those volumes which contains this holes is becoming difficult. Some volumes i could able to mesh. But some other volumes it is telling gap in face meshing is more. Because of this i am trying the same geometry in ICEM CFD SOFTWARE(just started learning). I heard that meshing difficulties won't be there in icem cfd software. Is it a good idea or what should i do.If u can help me in this regard i will be grateful.
thankyou
jyothish
[Commercial meshers] icem fluent mesh with cyclic boundary condition jiejie OpenFOAM Meshing & Mesh Conversion 2 February 24, 2020 03:34
[ICEM] Export unstructured periodic mesh from ICEM CFD to Fluent ivanddd ANSYS Meshing & Geometry 1 February 3, 2011 00:51
Import Fluent Mesh and Boundary Conditions BTU-RoRo CFX 3 July 23, 2010 14:20
mesh missing after import in fluent morteza08 FLUENT 0 July 23, 2010 02:22
Fluent error after import case from ICEM Lord Firestorm FLUENT 1 June 19, 2008 16:50
