Euler/Invisid
Old   June 17, 2004, 03:39
Default Euler/Invisid
Maria
Hi, Is there any difference between Euler and invicid flow???? Thanks
Old   June 17, 2004, 12:46
Default Re: Euler/Invisid
Arun
The euler equations are solved for an inviscid flow.
Old   June 22, 2004, 23:56
Maria
What is the difference between: Potential Flow Euler Flow Invicid Flow
Old   June 23, 2004, 16:11
Arun
Hi
The full Potential Flow equation is a subset of Euler Equations with the assumption of irrotationality. In the case of a compressible flow, another assumption is that entropy changes across shocks are neglected as long as the flow is close to Mach 1 (transonic flow regime). I really dont understand what you mean by the difference between Euler and Inviscid flow. They are the same. Good luck!
Arun
Old   June 24, 2004, 00:02
Maria
Thanks
