June 17, 2004, 03:39 |
Euler/Invisid
Hi, Is there any difference between Euler and invicid flow???? Thanks
June 17, 2004, 12:46 |
Re: Euler/Invisid
The euler equations are solved for an inviscid flow.
June 22, 2004, 23:56 |
Re: Euler/Invisid
What is the difference between: Potential Flow Euler Flow Invicid Flow
June 23, 2004, 16:11 |
Re: Euler/Invisid
Hi
The full Potential Flow equation is a subset of Euler Equations with the assumption of irrotationality. In the case of a compressible flow, another assumption is that entropy changes across shocks are neglected as long as the flow is close to Mach 1 (transonic flow regime). I really dont understand what you mean by the difference between Euler and Inviscid flow. They are the same. Good luck! Arun |
June 24, 2004, 00:02 |
Re: Euler/Invisid
Thanks
