Turbulence model
Old   October 3, 2004, 04:26
Default Turbulence model
sam
Which turbulence model is best for turbomachinery application if one just needs to have Qualitative analysis
can any body send me papers on review of turbuelnce models and turbulence models for turbomachinery application
This should be kept in mind that this is preliminary analysis of turbomachinery and it is still to be validated by eperiments
Old   October 4, 2004, 02:58
Default Re: Turbulence model
cem
I am using Fluent in Turbomachinery applications. I prefer to use RNG-ke turbulence model, it gives pretty good results for preliminary analysis. But it really depends on what kind of analysis, you want to perform.For example, in heat transfer coefficient calculations on blade surfaces, ke turbulence models do not give physical results. It is better to use kw models. Hope this gives an idea.
Old   October 4, 2004, 03:09
sam
But for my calculation in turbomachiery all three models (SA, Standard K E, and Reliazable have given same results quantitively and qualitively)
Then wat should i do
i am using standard wall fuctions in fluent
Wrong calculation of nut in the kOmegaSST turbulence model FelixL OpenFOAM Bugs 27 March 27, 2012 09:02
Low Reynolds k-epsilon model YJZ ANSYS 1 August 20, 2010 13:57
KOmega Turbulence model from wwwopenFOAMWikinet philippose OpenFOAM Running, Solving & CFD 30 August 4, 2010 10:26
Fan heater model: what turbulence source to use? andy20 CFX 7 March 3, 2008 16:42
SSG Reynolds Turbulence Model Georges CFX 1 February 28, 2007 16:15
