Boundary conditions for 2phase countercurrent flow |
December 18, 2003, 10:19 |
For countercurrent gas liquid flow in a packed column, how are the inlet boundary conditions to be defined? The top liquid inlet is also supposed to be outlet for the gas (gas will be bubbling out through the liquid surface) and at the same time, the gas inlet at the bottom is supposed to be liquid drain out area. Or is it that in the top and bottom plates, holes have to be defined separately as inlets and the rest as outlets. |
Free surface flow settubg boundary conditions and plotting velocity profiles | prashanthreddyh | FLUENT | 2 | October 21, 2015 09:58 |
Proper Pressure Boundary Conditions for Buoyant Flow | mchurchf | OpenFOAM | 0 | March 25, 2010 12:16 |
Heat Transfer boundary conditions for engine coolant flow simulation | rajuks | Main CFD Forum | 0 | February 15, 2010 09:04 |
RPM in Wind Turbine | Pankaj | CFX | 9 | November 23, 2009 04:05 |
boundary conditions for boundary layer flow | A. Al-zoubi | CFX | 0 | November 3, 2007 07:11 |
