December 20, 2004, 03:01 |
moving cylinder
i want to know how can a moving cylinder in a stationary fluid can be modeled by fluent and what is boundary condition?
December 20, 2004, 03:18 |
Re: moving cylinder
if u mean rotating cylinder on its axis ..you can use sliding mesh approach ...
December 20, 2004, 05:56 |
Re: moving cylinder
In my opinion you just give on cylinder wall(boundary condition)the rotational velocity. and that's all.
December 25, 2004, 02:39 |
Re: moving cylinder
thanks for your reply, i simulated a flow passes over a cylinder and the answers from fluent were correct, but the answers frome a cylinder that moves in a stationary flow were not equale with later model, how can i model a cylinder that moves to one direction and what are boundary condition?
December 25, 2004, 04:30 |
Re: moving cylinder
You should use the dynamic mesh to make your cilinder obscillating. You can impose the movement of the wall using a UDF. It's quite easy especially bacause you consider the cilinder undeformable.Luca
December 27, 2004, 14:38 |
Re: moving cylinder
The source of the discrepancy is most likely due to the fact that Fluent throws out the normal component of wall motion when you give it a moving wall boundary condition. Plot contours of the velocity component in the direction of the cylinder's motion to see that this is true. So the only options are to solve for relative motion, as you have done (good for "steady state" solution) or use the deformble mesh approach - forces unsteady solution, although you can let it achieve a constant solution to obtain a steady result.
Need advices for simulating vortex shedding of moving cylinder | quyetthang | CFX | 0 | October 1, 2011 05:39 |
Flow over a Cylinder. 2D vs 3D cylinder (moving) | ojha.mayank485 | CFX | 0 | June 20, 2011 15:25 |
Moving a Cylinder in cross flow after solving Dynamics equations of motion | maruthamuthu_venkatraman | OpenFOAM | 1 | November 19, 2009 13:55 |
moving cylinder | blur boy | Main CFD Forum | 4 | October 12, 2001 05:32 |
Confined or moving cylinder | Mohamed GUEROUACHE | Main CFD Forum | 1 | October 23, 1999 15:20 |
