February 16, 2005, 07:57 |
GAMBIT - Cooper Scheme
I'm stucked w/ a meshing problem while using a cooper scheme. I get this error message : Assertion failed in BarrelCapStack. cc, line 57: NULL != next_cap while meshing volume.17. Here is the description of my geometry: I have a 1 single volume that COULD be disretized in 3 volumes : the central one would be a regular hexahedron ; the two exterior ones would be two twisted hexahedra. total : 14 faces (6 source faces for the cooper scheme) any idea why the cooper scheme does not work fine here? Cheers, JB |
February 16, 2005, 21:01 |
Re: GAMBIT - Cooper Scheme
A cooper scheme fails only if a geometry converges to a pipe. why exactly do u want a cooper; A mapped hex could replace a cooper. But it all depends on what your lookin for!
February 17, 2005, 04:22 |
I think I just Cannot avoid a cooper : I have no choice but meshing several source faces of my volume w/ a Tri-pave scheme. But what do you mean by "A cooper scheme fails only if a geometry converges to a pipe" ? I'm sorry, my english is not perfect at all. Anyway, If someone got a similar problem, I found a trick to avoid the pb: just split the initial complicated volume into several simple ones. That way I don't get error messages anymore.
Cheers,JB |
February 17, 2005, 08:31 |
February 17, 2005, 08:32 |
Yes, I did have a similar problem and someone did say: Split and win. But , I had certain restrictions on splitting the volume. So, I said see what your lookin for and then make an optimum choice. Regards Samir.
Constant value by Cooper scheme | Mohsin | FLUENT | 0 | August 21, 2011 21:14 |
[GAMBIT] Boundary Layer without using Cooper scheme | Lilly | ANSYS Meshing & Geometry | 6 | March 17, 2011 15:14 |
Cooper Scheme Question (w/pics) | Forrest | ANSYS Meshing & Geometry | 2 | March 26, 2009 15:19 |
IMPRINT COMMAND IN COOPER MESHING SCHEME | TINA | FLUENT | 3 | October 7, 2006 05:03 |
Cooper Scheme | Sandy Lawson | FLUENT | 0 | December 14, 2004 06:43 |
