Fail in simulate 2D clocking of turbine
Old   March 29, 2005, 20:16
Default Fail in simulate 2D clocking of turbine
Jim
Hello everyone,
I use fluent 6 simulate three blade rows of turbine cascades. I first obtain a converged steady solution with mixing plane method, and this is taken as initial flowfield for time-accurate calculations with moving mesh selected. However, when I do this, the iteration process often stops as the downstream periodotic boundary of one blade nearly aligned with the upstream periodic boundary of next blade. At this moment, I run "Check" menu of Grid. There comes an unconventional message"Deleting Zone periodic-39(not referenced by grid)". I consulted with the service of Fluent in our country, but they say they also often encounter this problem, and they always overcome it by regenerate grid. I also regenerate grid for several times, but no use.
Who can resolve this problem? Is it the intrisic problem of Fluent?
Thanks for your attention.
Jim
Old   March 30, 2005, 04:53
Default Re: Fail in simulate 2D clocking of turbine
Jim
Waiting for answer....
how to simulate francis turbine and validate result gusri1208 FLUENT 2 March 18, 2014 12:20
simulate a gas turbine combustor with dieselFoam kikko OpenFOAM 0 September 23, 2011 20:32
I want to simulate a wind turbine in a yaw position ( lateral wind) mohammad FLOW-3D 1 January 17, 2011 01:41
how to simulate a wind turbine in a lateral wind? mohammad Main CFD Forum 0 January 2, 2011 03:08
How simulate air bubbles into water turbine? farzola Main CFD Forum 0 April 8, 2010 09:35
