The error message about interface
Old   November 19, 2005, 23:14
Default The error message about interface
braket
Hi, everyone
I am a greenhand in the FLUENT, and I need your help. I will appreciate it.
My model description ======================== In my model, I set two parts, one is channel and the other is diffusion layer which lies on the top of the channel. So I draw the two parts and put them together, and set the surfaces between them as the interface.
Problem description ======================== After set the boundary condition, and then initiate the model. The console shows the error message
WARNING: Unassigned interface zone detected for interface 6 Error: Init_Flow: unassigned interface_zones Error Object: ()
What's wrong with the model? What parameters need I change to correct the error? what mean's "Init_Flow"? Need I initiate the interface condition? If it is, how do I set the parameters of interface?
Thank you very much! Braket
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 04:05
CFX Solver Memory Error mike CFX 1 March 19, 2008 07:22
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 15:55
Replace periodic by inlet-outlet pair lego CFX 3 November 5, 2002 20:09
