December 12, 2005, 04:22 |
which Preprossecor Gambit Tgrid ....?
Hi every body which cad software is suitable? Autocad, Solid work, Pro Engineer,....?
which mesh gernerator is suitable? Gambit,Tgrid,Grid genertation,.....? Thanks |
December 12, 2005, 11:37 |
Re: which Preprossecor Gambit Tgrid ....?
I use AutoCAD for 2D geometry creation and CATIA for 3D. In autoCAD you can export your geometry to a .sat file that directly can be read with Gambit; with CATIA, and also with SolidWorks and Pro Engineer you can export in an easy way your geometry to IGES and then import it to Gambit.
I've heard in other posts here in CDF-online that Gambit is now an old-fashioned grid generator, but it is which I am working with: perhaps GridGen would be a better choice, but I haven't work with it. Tgrid is your choice when you've done (in gambit, for example) your surface mesh of your 3D model and wand to create a fast 3D grid with (merhaps millions) tetraedrons and with capability for create boundary layers made with prismathic elements extruded from your surface mesh. Hope it was clear and helpful. |
December 13, 2005, 01:16 |
Thanks I heared when you use solid work and export it to Gambit you loss some fine curve.
[Commercial meshers] Cannot convert fluent or tgrid hexcore mesh | aerogt3 | OpenFOAM Meshing & Mesh Conversion | 2 | October 22, 2010 11:55 |
CFX Pre - TGrid | Vivek Vasudevan | CFX | 2 | March 20, 2007 06:31 |
TGrid: segmentation violation error | Vincent | FLUENT | 0 | February 15, 2006 10:34 |
Drawing in TGrid | Harmeet | FLUENT | 0 | September 22, 2004 03:56 |
to tgrid or not to tgrid | Nurul Murad | FLUENT | 1 | July 6, 2001 13:21 |
