[Sponsors] | |||||
Hi
I used GAMBIT to create a .dbs file (what was originally a .igs file). I now want to chech the grid/mesh for any errors before actually running it in FLUENT/FIDAP. IS this possible at all? Also, how do I import this .dbs file into FLUENT at all? I tried to export the file from GAMBIT as a .msh (mesh) file but I end up getting it as a .fdneut or .fiprep file. Can someone help? Ravi Doddas |
In Gambit first see that the solver is set under Fluent 5/6 when you create the grid and put boundary conditions.
Then export the mesh. It should be then under File type: UNS /RAMPANT /FLUENT 5/6. If you are trying a 2D grid, then check the Export 2-D (X-Y) Mesh button. By default it is 3D. It will create a file with extension *.msh. You can then import that *.msh file into Fluent. Hope it helps you. |
You can also check the mesh in Gambit for skewness, aspect ratio, etc...it is the bottom right button (a mesh with a lens over it).
Once in fluent, when you load the .msh file the grid is automatically checked, or you can do it with grid>check Edi. |
Yeah it does...thanx a lot...
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| [ICEM] Unstructure Meshing Around Imported Plot3D Structured Mesh ICEM | kawamatt2 | ANSYS Meshing & Geometry | 17 | December 20, 2011 11:45 |
| Mesh motion with Translation & Rotation | Doginal | CFX | 0 | August 3, 2011 16:37 |
| Kubuntu uses dash breaks All scripts in tutorials | platopus | OpenFOAM Bugs | 8 | April 15, 2008 07:52 |
| fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
| OpenFOAM installation problem on Linux 32bit | kumar | OpenFOAM Installation | 0 | April 27, 2007 05:41 |
