Help with particle diameter in a cell
Old   March 1, 2006, 09:51
Default Help with particle diameter in a cell
Josh
This is a gas flow coupled with DPM problem. The Micro only have c, t as variable but I need the particle diameter in a cell, how can I make a connection between them? Thank a lot!
Old   March 1, 2006, 12:50
Default Re: Help with particle diameter in a cell
Allan Walsh
Look in UDF manual for particle properties.
Cells with t below lower limit Purushothama Siemens 2 May 31, 2010 21:58
DPM UDF particle position using the macro P_POS(p)[i] dm2747 FLUENT 0 April 17, 2009 01:29
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 04:15
Warning 097- AB Siemens 6 November 15, 2004 04:41
Iclude particle diameter effect in wall? yueroo FLUENT 0 April 14, 2001 03:56
