running Fluent on a DUAL CORE system
Old   June 16, 2006, 10:12
Default running Fluent on a DUAL CORE system
Ralf Schmidt
Hi all!
We want to get a new PC System, to run Fluent on. It is a dual core system. Can Fluent run without problems on that machine? Has anyone experience with that kind of setup??
The Fluent webside says, it runs on a MD64/Opteron platform with Operating System: SUSE 9.0, 9.1; SUSE SLES 9 and 64 bit.
The system we want to buy is a: 2 x AMD DualCore Opteron 270 (2Ghz) Sockel 940 FSB1000, 2MB Cache with 8 x 1GB DDR RAM /PC400 ECC reg.Single Rank.
Are there any restrictions with the use of shared fluent licences ("Academic renewal", licence type: floating)?
Are there better machines for the same price (about 3000 Euro)??
Thanks for help
Ralf
Old   June 19, 2006, 15:58
Default Re: running Fluent on a DUAL CORE system
Evan Rosenbaum
Two cores = two licenses. FLUENT has told us that a dual core will NOT perform like a dual processor. It will be faster than a single-core single-CPU machine, but still slower than a true dual-CPU box. Bandwidth is king, so get the fastest FSB you can in a dual-core.
Old   June 20, 2006, 07:15
kerem
Hi Ralf, hi Evan,
I can't compare it with a true dual-CPU machine, but to my experience, it is indeed much faster than a single-core one.
peace.
Kerem
Old   June 20, 2006, 10:21
grisu
If I run 2 single jobs on a dual core machine, fluent is approx. 2-3 % slower than if I run these jobs on separate machines (comparison done with AMD X2 4200/AMD 3500 @ 2.2 GHz).
Same is valid when doing parallel jobs - the speedup compared to single cpu is approximatly the same as if you use 2 cpus (anyway - the speedup will only be 1.5-1.7 times, depending on the models you use).
CFX11 + Fortran compiler ? Mohan CFX 20 March 30, 2011 18:56
Fluent lmgrd is not running shrikant_fromchicago FLUENT 0 March 2, 2010 01:30
OpenMP,MPI and dual core Quarkz Main CFD Forum 2 December 7, 2007 19:29
Core 2 Duo vc. Dual Core Xeon 3060 Jan Main CFD Forum 6 February 20, 2007 06:21
