Torque calcuation
Old   June 29, 2006, 16:01
Default Torque calcuation
Mary
How can I calculate the torque of the impeller blade in a stirred tank reactor?
Old   June 29, 2006, 23:17
Default Re: Torque calcuation
mAx
Report/Force Choose Moment and the axis-rotation (also the center of rotation) of your impeller
Old   June 30, 2006, 08:56
Mary
Thanks 4 yr mail. Can u use this moment as a criterion for the stability of my model? If it does converge, do u know why?
Old   July 3, 2006, 00:53
mAx
sure: if you monitor the torque on a piston and it doesn't remain stabil (oscillations) then it is possible that you have unsteady phenomen
Old   July 3, 2006, 09:49
Fluent learner
Hey Mary,
I have been trying to model rotating blades. Can youn tell me how you set up Fluent for the case of your impeller blades?
Old   July 6, 2006, 19:53
Mary
How do u mean? Have u modelled your tank? If so, u read yr case file into fluent. there are two methods: Multiple frame of reference or Sliding mesh. Check Fluent tutorial for this. does this help
Old   July 11, 2006, 10:50
Fluent learner
Actually my case is not of impeller blades, it is of rotating helicopter blades, so there is no tank, there is only a pressure far-field. Can you tell me how to set up the problem? I have tried to make the fluid rotate in a direction opposite to that of the blades and keep the walls stationary (in this rotating frame). But this does not give the correct solution. I have looked up the fluent tutorials, but since they only show 2D cases in them, they were not much of a help. I checked some previous posts on this forum too, but the problem is not resolved. Can you tell me step-by-step, how you set up the wall and fluid boundary conditions for the case? I am using a Spalart-Allmaras turbulence model, coupled implicit solver. Thanks in advance, this will be great help.
NY.
Torque calculation of 2D VAWT Wind Turbine Anonymized_JL1 FLUENT 14 September 26, 2013 03:35
FloWorks torque bug? PJC FloEFD, FloWorks & FloTHERM 0 November 8, 2009 18:41
positive and negative torque forces Wei-Haur Lam CFX 0 March 19, 2008 07:45
Torque definition Yali CFX 2 January 7, 2008 03:13
about use macro to compute torque in TASCflow lancy CFX 0 June 10, 2003 06:19
