packed bed
Old   August 31, 2006, 05:01
Default packed bed
rakesh
can any body help me in simulating the packed bed by 'porous media approach',
thanks
Old   September 1, 2006, 01:21
Default Re: packed bed
Wilson
Rakesh
Yes I can help you on this. What you really need on porous media approcach? Please me elaborate.
Thanks Wilson
Old   September 1, 2006, 04:56
Default packed bed
Rakesh
Thanks for responding, actually i m trying to simulate a simple case of packed bed,1m length and 100mm dia,packed with 10mm glass beads(density 2500kg/m3. now air is flowing to upward direction from bottom with 0.5 m/s. i m selecting the following options. define-models-solver-axisymmetric,unsteady define-models-viscous-laminar materials-air as default operating conditions-operating pressure=101325 as default enabling gravity X=-9.81, Y=0 enabling specified operating density option. boundary conditions-enabling porous zone option-direction-1 vector 1,0 as default,viscous resistance direction 1=4828045, dirction 2=0 as calculated form the formula given for packed bed, inertial resistance direction 1= 2054.495 ,direction 2=0 power law coefficient C0=0, C1=0, porosity =.453 given as experimental value.
solve- initialize-inlet-velocity =0.5.
after iterating the above i m not geting the desired result of pressure drop.
any kind of help in this regard is welcome
thanks
Max.allowable flow rate in a packed bed Mamata FLUENT 3 May 29, 2017 12:33
porosity in packed bed with eulerian multiphase Sree FLUENT 1 April 15, 2015 06:17
urgent... multiphase cfd model of packed bed reactor.( VOF MODEL using) balu@gold6 FLUENT 4 July 26, 2012 10:37
Packed bed using euler-euler akm FLUENT 0 May 28, 2010 05:40
Fluid flow in packed bed Prakash Verma FLUENT 2 August 9, 2004 07:11
