Large eddy simulation
Old   December 6, 2006, 08:28
Default Large eddy simulation
David
Hey,
I am currently performing LES for turbulent channel flow at a reynolds number of 9000. I have 3 questions,
1. Should i perform a RANS calculation first until the flow has developed
2. Which is the best SGS model to use
3. At what point in the simulation should i begin data sampling for time statistics.
I have performed several simulations laready but the results are not what i was expecting as the rms velocity plots are not similar to results obtainbed from DNS calculations. Any help would be greatly appreciated
Thanks in advance
Old   December 11, 2006, 12:18
Default Re: Large eddy simulation
hugo
Hi David, I'm currently performing a LES for turbulent channel flow but a Reynolds number of 200000. First I always perform a RANS calculation (this is advisable for the first calculation). Second i don't know what is the best SGS model but some peoble use an Smagosinsky model with a diferent value of the constant Cs. Third, i begin data sampling for time statistics after 1000 time steps then, Fluent user's manual recomend between 1000 and 10000 time steps with data sampling.
Are you performing a wall function with LES? because i am trying to model a full development flow with LES in a circular straight channel flow but with a very fine mesh near de wall (y+ aprox 1) without wall function and the results in the boundary layer with LES are different than teorical and RANS. Can somebody help me?. i'm using a periodic condition in a duct with 3 hidraulic diameters.
i also have problem to select the correct size mesh and the correct time step for LES.
What are BUDGET TERMS in Large Eddy Simulation??? mariachi FLUENT 1 January 23, 2010 03:36
Large Eddy Gernot FLUENT 3 July 27, 2005 10:20
Large Eddy Simulation of helium jets Rajani FLUENT 0 February 19, 2004 12:25
LARGE EDDY SIMULATION Parshant Dhand FLUENT 0 May 19, 2003 22:12
Large Eddy simulation Andreas Hauser Main CFD Forum 1 May 20, 2000 20:33
