Problem in FLuent
Old   January 23, 2007, 08:23
Default Problem in FLuent
Malay
When I run fluent from our institute server from any remote comp using linux, I get the following message as an error when I choose to display any plot/contour,iteration residual graph, etc.
"OpenGL cannot find visual"
But when I run it from any computer from the lab, I can do just fine.
My Linux is FC5 while lab OS is FC2.
Even lab people are perplexed why this error comes. Can anyone help me out as to what could be the problem? Thanks...
Old   January 23, 2007, 09:09
Default Re: Problem in FLuent
cle3000
You need Exceed to be installed on your computer.
Old   January 23, 2007, 10:06
cle3000
Sorry .. I didn't see that you are running linux and not windows. When you start Fluent in your command window add the option -x. That usually works.
Old   January 23, 2007, 23:59
Muke
Please type the following command when you launch fluent. fluent [version] -driver x11 for unix/linux
Basically your graphics driver card is not supported. You may need to upgrade your driver of grpahics card which is available free of cost on the site of your graphics card vendor.
Old   January 30, 2007, 05:45
Malay
Thanks a lot man... using "-driver x11" command solved the problem... thanks again
fluent parallel problem in win7 x64 system dunga82 FLUENT 8 April 19, 2012 20:23
Problem in IMPORT of ICEM input file in FLUENT csvirume FLUENT 2 September 9, 2009 01:08
Fluent boundary conditions problem bobo FLUENT 2 July 3, 2009 06:28
Fluent parallel license problem brothershuai Main CFD Forum 0 July 1, 2009 15:41
Fluent problem Z FLUENT 1 April 8, 2005 04:22
