how to check the retained data of each design point
Old   December 5, 2017, 02:48
Default how to check the retained data of each design point
Fei Li
wonkyman is on a distinguished road
Hi, i'm new for ANSYS fluent. Right now I'm using fluent 18.2 to do simulation on supersonic nozzle. I set the inlet pressure as design point and update all with the retain data being checked. How can I check the retained data like the density, pressure, etc for each DP?
wonkyman is offline   Reply With Quote
design points, fluent, parameter set
[GAMBIT] periodic faces not matching Aadhavan ANSYS Meshing & Geometry 6 August 31, 2013 11:25
[ANSYS Meshing] Importing Cylinders by Point Data Input with Radii EphemeralMemory ANSYS Meshing & Geometry 2 May 31, 2012 13:34
block-structured mesh for t-junction Robert@cfd ANSYS Meshing & Geometry 20 November 11, 2011 04:59
matching variable data with grid point data anfho OpenFOAM Programming & Development 0 May 6, 2011 15:28
Problems in compiling paraview in Suse 10.3 platform chiven OpenFOAM Installation 3 December 1, 2009 07:21
