inlet BC using UDF
Old   April 18, 2007, 06:06
Default inlet BC using UDF
sam
At the inlet i want to give a boundary condition which is the d(uds 0)/dt. so for this which macro to use?
I have tried DEFINE_INIT and DEFINE_PROFILE.
Both gives me an error during initialization of the solution.
Plz help
Old   April 23, 2007, 08:21
Default Re: inlet BC using UDF
steadman
I think it is simple there many macros in udf that you can use to write you program, you'd better see the help file for details.
UDF for inlet mass flow rate rahulsuresh89 Fluent UDF and Scheme Programming 1 October 16, 2010 17:06
UDF parallel velocity inlet profile Armengol FLUENT 3 September 30, 2009 15:08
Fluent UDF load and apply inlet velocity b.c. Knut Lehmann Main CFD Forum 2 June 29, 2007 04:53
UDF 3D inlet b.c. problem Andrew FLUENT 4 May 25, 2004 04:24
find the best inlet with udf Tuckbros FLUENT 0 May 20, 2004 12:56
