April 18, 2007, 15:47 |
memory
have you ever had this error? the mesh I have has 1346108 nodes. The memory on the computer is 4GB RAM. Any advice? Thanks Warning: ST_Malloc: out of memory.malloc_storage: unable to malloc Body Force Corr |
April 19, 2007, 13:15 |
Re: memory
Hi, is it required any configuration to make FLUENT using all the available memory? thanks
April 20, 2007, 11:49 |
Re: memory
Hi, first of define your OS, number of cpu's, solver settings . This error might happen if you are running Fluent under 32-bit XP with coupled solver. In this case memory limit per cpu is 2gb and it is not enough for coupled solver and your mesh.
April 20, 2007, 14:07 |
Re: memory
Thanks Albert, actually I'm using Fluent under 32bit XP with a dual core. what do you mean in defining the OS and how to define the # of CPU?
How to optimize the memory usage when using FEM | vasilis | Main CFD Forum | 11 | August 24, 2009 23:57 |
Memory error? | Young | CFX | 3 | September 30, 2008 11:33 |
Out of Memory | Naghman Khan | FLUENT | 3 | August 30, 2007 06:08 |
CFX CPU time & real time | Nick Strantzias | CFX | 8 | July 23, 2006 17:50 |
Run-Time memory conifguration Error | Graeme | CFX | 1 | February 20, 2006 23:04 |
