Airfoil 2D, very weird result
Old   June 12, 2007, 14:15
Default Airfoil 2D, very weird result
Martin
Hello, I'm doing simulation on airfoil. Rn: 400 000 I'm not able to obtain a good lift or drag coeficient. I'm getting lift coefficient in the 500 to 2500 range and sometime negative drag! (wow that a revolution!) When I reduce the speed by 2 the Cl reduce by approx. 4!
I can't understand why. I also tryed the Cornell tutorial and i'm getting crazy result, I tryed the fluent tutorial about 0.8 mach airfoil... calculation error.. and that even if i'm using my mesh or the one from the tutorial!
Someone had this problem?
Old   June 12, 2007, 15:28
Default Re: Airfoil 2D, very weird result
Charles
Set the reference values ....
Old   June 13, 2007, 03:24
Dr. Flow Squad
Monitor the forces on the wing to see if the forces are constant for each iteration.
Old   June 13, 2007, 06:34
pinks
hi are you peforming tutorial from Fluent 6.2.16/6.3?
Old   June 13, 2007, 12:21
Martin
Hello, The reference value was a big part of the problem... Long time i did any simulation and i forgot that setting. I was monitoring the force and in fact it was looking fine: no fluctuation and was looking like converging but in fact i was not. I changed the solver to coupled implicit and now thats fine!
A last question: The Cl sem very good but de Cd is not that good. I wanna be sure that the Cd given by fluent is relative to the frontal aera of the airfoil. And that in practice the Cd given in airfoil spec is relative to the surface of the wing...
Thanks Martin
Low Speed Airfoil Mancusi FLUENT 7 April 3, 2014 06:11
Comparison the airfoil 0012 experimental result and simulation result harrislcy FLUENT 30 August 29, 2013 10:27
result on airfoil wortmann fx63-137 simulation jdfortune FLUENT 5 January 31, 2011 19:26
Weird Intepolation Result.. dokeun FLUENT 0 May 6, 2010 09:22
Airfoil boundary condition Frank Main CFD Forum 1 April 21, 2008 18:36
