Particle injections
Like Tree1Likes
Old   September 4, 2014, 00:31
Default DEM simulation
  #21
Naval V.Koralkar
nkidol08 is on a distinguished road
Hii
Can any one mail me with the udf for particle injection I am working on 2d as well 3D system with around 12000 and 1 lac particles
nkidol08 is offline   Reply With Quote
Old   July 20, 2016, 03:24
Default injection file format
  #22
Nuha
Nuha is on a distinguished road
Hi
please mail me udf or any related document on file injection format and its usage at fluent.
my email id is : amnaamanat73@gmail.com
Best Regards
Nuha
Nuha is offline   Reply With Quote
Old   July 20, 2016, 11:10
Default DPM Approach. particle trajectories
  #23
Saxony Anhalt
umairjamil is on a distinguished road
Originally Posted by Madhukar
;142967
Amir,
I can send you the UDF i am using if you would like to see.
Regards
Madhukar
Hey there, I am as well trying to simulate the trajectory of particles in a spray dryer. I would really like to try this UDF so i could control my number of particles and have a better view of their trajectory. I would be very grateful if you could send it to me on umair35@gmail.com.
Thank you very much.
Regards,
umairjamil is offline   Reply With Quote
Old   April 3, 2018, 03:44
lilirong
piaoyangdexue is on a distinguished road
Hello, I also do the same simulation, did you get the UDF for the case, if you had, would you like to share with me?
piaoyangdexue is offline   Reply With Quote
Old   April 8, 2018, 14:49
Bhargav Bharathan
bhargavbharathan is on a distinguished road
You don't need a UDF. Go to Models -> Discrete phase -> Injections and set up your case. Initially there will be a dummy material as the injected particle. You can change it's properties under materials.
-BB
bhargavbharathan is offline   Reply With Quote
Old   August 27, 2019, 09:24
Default Injecting large ammount of DEM particles with file
  #26
Gerrit Botha
gbot is on a distinguished road
Hi All
I have a question regarding the injection of DEM particles into fluent.
Trying to model a spouting bed. The file I am reading has around 6million particles and trying to inject it within the first time step.
My question is whether the file reading process is done in parallel or serial, as it is currently take +3h for the particles to load? Is there a way to speed the process up, such as injecting it over a longer time period or reading different smaller files?
Regards
gbot is offline   Reply With Quote
Old   January 13, 2020, 23:45
Ahmed
ahmedazzani is on a distinguished road
;142967
Amir,
Regards
Madhukar
I’d appreciate it if you send the UDF file to me too.
ahmedazzani92@gmail.com
Regards
Ahmed
ahmedazzani is offline   Reply With Quote
Old   January 24, 2020, 04:11
Aizh
aizhanmardiyeva is on a distinguished road
Hello, Can anybody send me udf, please. aizhanmardiyeva@gmail.com
aizhanmardiyeva is offline   Reply With Quote
Old   November 29, 2021, 02:28
Jake C
JAKE-CU is on a distinguished road
I would also greatly appreciate if you could share the UDF you are using. johnecastellini@gmail.com
JAKE-CU is offline   Reply With Quote
Defining DPM Particle Injections with a UDF TedBrogan FLUENT 0 April 18, 2011 16:45
Time delay particle injections denyfrank FLUENT 0 February 3, 2011 14:04
Multiple surface particle injections from the command line mbeals FLUENT 0 June 3, 2009 14:11
DPM UDF particle position using the macro P_POS(p)[i] dm2747 FLUENT 0 April 17, 2009 01:29
Particle injections Virag Mishra FLUENT 0 August 22, 2007 05:11
