Fluent coupled with external process
Old   July 10, 2007, 09:35
Default Fluent coupled with external process
Nitesh Goyal
Hello everyone!!
We are dealing with a Server Client Interface on a coupling problem between Fluent and Rad-Therm implemented as a C++ program.
When the coupling is executed, the library hooked into Fluent is able to write and re-read the file just created but could-not read any file created by an external process, namely the process which started Fluent in batch mode.
It is not a matter of rights for giving the textfile all rights in Linux (777) does not help.
Neither is it a matter of synchronization, as the file is first created and then the fluent process started.
Please give some input on how to read this text file.
Feel free to send an email, if you need further information
With regards
Nitesh Goyal.
Parallel fluent not using all processors specified Paul FLUENT 18 October 26, 2023 03:54
Abaqus - Fluent Coupling WITHOUT MPCCI s.mishra FLUENT 1 April 5, 2016 06:47
On Bug of Fluent 12.0 lzgwhy FLUENT 0 August 26, 2009 06:41
Modelling Sintering Process with Fluent Saeed FLUENT 0 October 20, 2007 06:56
coupled solver in FLUENT ztdep FLUENT 1 September 14, 2006 22:34
