Surface reaction rate
Old   December 15, 2007, 19:37
Default Surface reaction rate
Jon
Hello
I want to model the O2 consumption on tissue surface as Michaelis-Menten equation, which states:
R=Vm*Ci/(K+Ci)
where Vm and K are constant and Ci is O2 concentration at the wall. In UDF (DEFINE_SR_RATE) Ci is defined by the molar concentration, therefore I have to convert it by multiplying the mass fraction of O2 by density and divide it by the molar weight, am I right?. I think the density must be defined at the centre not the face and in surface reaction is defined at the face, so how can I get the density at the cell centre? please help!!.
Thanks
Old   December 17, 2007, 04:20
Default Re: Surface reaction rate
saghir
DEFINE_SR_RATE(user_rate,f,t,r,mole_weight,species _mf,rate) {
dcell = C_R(F_C0(f,t),t->t0); *rate = /*kmol/m2-s */ }
Old   December 17, 2007, 10:23
Judd
Hi Saghir,
Thanks, but can please explain more?. I tried to do like this:
Thread *t0=t->t0;
cell_t c0=F_C0(f,t);
c1=C_R(c0,t0)*s1/mw1;
but i got this msg "structure reference not implemented".
Regards
Old   December 17, 2007, 10:43
saghir
you must write directly
reel dcell; dcell = C_R(F_C0(f,t),t->t0); or
Thread *t0; cell_t c0; c0 = F_C0(f,t); t0 = THREAD_T0(t); reel dcell; dcell = C_R(c0,t0);
Old   December 18, 2007, 00:46
suribabu
hi, can u explain about ur problem.
Old   December 19, 2007, 07:01
Judd
Thanks Saghir,
i guess my problem is in the compiler, I will try to install a new one and try agin. many thanks,
Hi Suribabu, my problem is mentioned in the first post here by Jon.
Regards,
methane steam reforming reaction rate... yerem3 FLUENT 0 August 30, 2010 09:43
mass flow rate on the Iso-clip surface & interior Sunil Gupta FLUENT 0 April 22, 2008 09:29
Wall Surface Reaction!!!! ansonkuo FLUENT 0 December 24, 2007 02:15
accessing sover data for surface deposition rate Ashish Jain FLUENT 0 June 4, 2005 03:39
backwards surface reaction Andrew Garrard FLUENT 2 May 15, 2003 08:14
