February 3, 2008, 21:20 |
BC compatibility
Currently am modeling a section of duct with several features present within the flow stream including a porous screen. I want to mesh the inlet as a 'Mass Flow Inlet' BC so compressibility effects can be accounted for, and a 'Velocity Inlet' BC is not possible for this. The duct expels into the atmosphere in a plume. The outlet BC is modelled as a 'Pressure Outlet'. When solving I get a "Floating Point Error: Invalid Number" message. When going to a velocity inlet it will solve fine. Is there an incompatibilty problem present?
February 4, 2008, 09:27 |
Re: BC compatibility
of course, boundary condition muss consist with physical property of the flow, mass flow in--mass flow out or velocity out pressure in--pressure out or velocity out
if you are given mass in, but pressure out, it is extremly difficult to resolve for pressure at inlet, or velocity at outlet;it is almost impossible, not that i know |
Compatibility OpenFOAM 1.6 and 1.7.1 | Ale_galleria | OpenFOAM | 2 | September 20, 2010 09:14 |
compatibility fluent 12.1 with fluent 6.3 | ak6g08 | FLUENT | 4 | September 9, 2010 11:07 |
[ICEM] v10 and v11 compatibility problem | Sofia | ANSYS Meshing & Geometry | 4 | August 5, 2010 07:29 |
Compaq VF and Intel VC compatibility issues... | Ford Prefect | Main CFD Forum | 0 | May 5, 2005 23:58 |
Compatibility equations | Stefan Maehlmann | Main CFD Forum | 0 | January 22, 2001 03:39 |
