Gambit HEX core method gives unwanted 2D region
Old   February 3, 2008, 05:21
Default Gambit HEX core method gives unwanted 2D region
KK
Hi there,
I meshed one conical volume with Hexa-core method and it gave me a very GOOD quality HEX dominated mesh with few layers of pyramids and prisms around hexa.
But When I save the mesh in ANSYS format to import in CFX-11, I see that mesh contains a 2D primitive region right where pyramids start around the region of HEX elements. But I did not define or create this region in Gambit. I do not want to have this 2D region created at all because this gives me problem in CFX-11(It would fall under wall category).
1) I do not understand how come this 2D region exists. Any idea? Is it a problem with HEX-core scheme?
2)Is there any way out to get rid of this region?
3) Will saving the mesh in some other format work?
Thanks a lot in advance for your help !
Best Regards, KK
Old   February 4, 2008, 09:31
Default Re: Gambit HEX core method gives unwanted 2D regio
jesse
i dont know CFX much,but principally you can manipulat mesh in CFX like in fluent(merging, split,...),(in CFX pre),right?maybe you should post you question in CFX Forum
[Commercial meshers] Using starToFoam clo OpenFOAM Meshing & Mesh Conversion 33 September 26, 2012 04:04
[ICEM] how can i create a consistent transitions between tet and hex? specifically my model? snailstb ANSYS Meshing & Geometry 3 March 15, 2010 20:26
[Other] StarToFoam error Kart OpenFOAM Meshing & Mesh Conversion 1 February 4, 2010 04:38
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 04:15
[Gmsh] Import gmsh msh to Foam adorean OpenFOAM Meshing & Mesh Conversion 24 April 27, 2005 08:19
