April 30, 2008, 12:41 |
Meshing a small section in GAMBIT
I am modeling a 8 degrees section of a system. I have a hard time getting a nice mesh, and it seems that I can only use the tri/hex mesh option. I end up having very skewed meshes in the volumes close to the axis and FLUENT ends up diverging after a few iterations. Anybody has ever had to model such a wedge with small angles
May 1, 2008, 04:52 |
Re: Meshing a small section in GAMBIT
You should be aware of the basic principle of FVM. In sharp edges would be always finite high skewed grid cell and representation of results would be very spurious, even if you have very fine mesh. You could simply cut the sharp edge with a plane in sharp edge - plane distance which is acceptable for you. Then , you can get much better mesh, even hex meshing is possible.
good luck , H.B. |
May 2, 2008, 11:51 |
Hi Anne,
I have a similar problem of meshing a 10 deg section. Did you find a solution for your problem? Varun |
May 2, 2008, 11:58 |
No I have not. I was trying to think of how I could implement a plane close to the axis, but I am not sure what kind of boundary I should use.
May 12, 2008, 12:04 |
For pie wedges, I redefine the node on the axis to force a triangle facet on the face mesh at that node.
Then I mesh the face with pave. Sometimes I put a sizing function at the node. R. |
small Gambit menu problem | Subhash C. Bose | FLUENT | 5 | July 18, 2010 06:20 |
meshing very small tubes | Wooster | CFX | 6 | July 23, 2007 10:41 |
Gambit: mesh size to small??? | Ralf Schmidt | FLUENT | 1 | January 28, 2006 01:26 |
Meshing a domain with very small slit using Gambit | Rucy | FLUENT | 0 | November 14, 2005 02:29 |
Problems meshing a pie-shape cross-section bar-suggestions or workarounds needed | Ricky Wong | FLUENT | 1 | May 11, 2000 17:35 |
