Meshing a small section in GAMBIT
Old   April 30, 2008, 12:41
Default Meshing a small section in GAMBIT
Anne
I am modeling a 8 degrees section of a system. I have a hard time getting a nice mesh, and it seems that I can only use the tri/hex mesh option. I end up having very skewed meshes in the volumes close to the axis and FLUENT ends up diverging after a few iterations. Anybody has ever had to model such a wedge with small angles
Old   May 1, 2008, 04:52
Default Re: Meshing a small section in GAMBIT
bohis
You should be aware of the basic principle of FVM. In sharp edges would be always finite high skewed grid cell and representation of results would be very spurious, even if you have very fine mesh. You could simply cut the sharp edge with a plane in sharp edge - plane distance which is acceptable for you. Then , you can get much better mesh, even hex meshing is possible.
good luck , H.B.
Old   May 2, 2008, 11:51
varun
Hi Anne,
I have a similar problem of meshing a 10 deg section. Did you find a solution for your problem?
Varun
Old   May 2, 2008, 11:58
Anne
No I have not. I was trying to think of how I could implement a plane close to the axis, but I am not sure what kind of boundary I should use.
Old   May 12, 2008, 12:04
R.
For pie wedges, I redefine the node on the axis to force a triangle facet on the face mesh at that node.
Then I mesh the face with pave. Sometimes I put a sizing function at the node.
R.
small Gambit menu problem Subhash C. Bose FLUENT 5 July 18, 2010 06:20
meshing very small tubes Wooster CFX 6 July 23, 2007 10:41
Gambit: mesh size to small??? Ralf Schmidt FLUENT 1 January 28, 2006 01:26
Meshing a domain with very small slit using Gambit Rucy FLUENT 0 November 14, 2005 02:29
Problems meshing a pie-shape cross-section bar-suggestions or workarounds needed Ricky Wong FLUENT 1 May 11, 2000 17:35
