DPM - do the particles affect the liquid?
Old   January 1, 2009, 11:58
Default DPM - do the particles affect the liquid?
Nikhil Dani
Hello folks,
I am using Discrete Particle Modeling (DPM). I know that DPM assumes the particles as point masses, with the diameter and the density used only to calculate parameters like the Body Force, and have no physical significance.
Since the particle diameter is used for evaluating the body force, which in turn governs the motion of the particles in a fluid medium, it means that the DPM certainly looks at the fluid interacting with the particles.
However, my question is, does DPM account for the effect that the particles have on the fluid? Do these particles transfer any momentum back to the fluid? Or is DPM formulated on the assumption that the particles are too small to cause any significant change to the fluid flow pattern.
Thanks, Nikhil
2 phase flow liquid flow solid particles sachin OpenFOAM Running, Solving & CFD 0 August 28, 2008 16:51
how does it affect???????? jamal FLUENT 3 January 15, 2008 23:05
How much surfactant affect surface tension qunwuhe@hotmail.com Main CFD Forum 0 June 7, 2007 05:01
How surface tension affect delta t? Pei-Yng Hsieh Main CFD Forum 3 February 25, 2005 10:55
will Turbulence affect solution joe CFX 2 June 25, 2002 18:06
