February 10, 2009, 10:41 |
UDF array problem
Colleagues,
I would be interesed in any suggestions on the following. I am using Fluent 12 beta release. Below is part of a udf to define a periodic boundary condition at the inlet. I've had this bc working in earlier versions of fluent. My problem concerns the initiaisation of a number arrays at the beginning of the routine. The routine starts by intialising the arrays radexp, a0, a and b. The routine compiles, builds and loads ok using ms visual c++ 2008. On intialising the flow field using the compute from 'inlet' the routine appears to read (from file) and write (to screen) the arrays radexp, a0, a and b correctly. However when I try to write a after reading b the elements of a become jumbled. This coding worked fine on versions of fluent prior to 6.4. Any help, suggestions greatly appreciated. I have tried reading and writing the arrays using pointers but I get the same result. #include "udf.h" #define M 128 #define N 13 DEFINE_PROFILE(inlet_velocity,thread,index) { FILE *fp; int i, j; float radexp[25], a0[13], a[128][13], b[128][13]; real x[ND_ND]; face_t f; real xcoord, ycoord, zcoord, radcfd; fp = fopen("PBFFT12.txt","r"); for (i=1; i<N; i++) { fscanf(fp, "%f", &radexp[i]); radexp[i] = radexp[i] * 0.001; //0.001 converts from mm to m } for (i=1; i<N; i++) { printf("%12.8f ", radexp[i]); } printf("\n"); for (i=1; i<N; i++) { fscanf(fp, "%f", &a0[i]); } for (i=1; i<N; i++) { printf("%12.8f ", a0[i]); } printf("\n"); for (j=1; j<M; j++) { for (i=1; i<N; i++) { fscanf(fp, "%f", &a[j][i]); } } for (j=1; j<3; j++) { printf("%4d ", j); for (i=1; i<N; i++) { printf("%12.8f ", a[j][i]); } printf("\n"); } for (j=1; j<M; j++) { for (i=1; i<N; i++) { fscanf(fp, "%f", &b[j][i]); } } for (j=1; j<M; j++) { printf("%4d ", j); for (i=1; i<N; i++) { printf("%12.8f ", b[j][i]); } printf("\n"); } for (j=1; j<M; j++) { printf("%4d ", j); for (i=1; i<N; i++) { printf("%12.8f ", a[j][i]); } printf("\n"); } fclose(fp); begin_f_loop(f,thread) /* loops over all faces in the thread passed in the DEFINE macro argument */ { // get the co-ordinates of tri-face centre F_CENTROID(x,f,thread); // set velocity at the tri-face centre F_PROFILE(f,thread,index) = 0.02; } end_f_loop(f,thread) } |
array in UDF | Kamal | FLUENT | 1 | November 7, 2013 01:15 |
Array problems | Malachy | FLUENT | 2 | March 5, 2012 15:11 |
can we initialize an array in UDF? | blueberry | Fluent UDF and Scheme Programming | 2 | April 14, 2009 12:00 |
Array declaration | kdarc | OpenFOAM Running, Solving & CFD | 0 | August 23, 2007 23:21 |
Increasing the F-array - Problem! | Bernardo Santos Aflalo | Phoenics | 2 | April 25, 2006 14:07 |
