UDF array problem
Old   February 10, 2009, 10:41
Default UDF array problem
Malachy
Colleagues,
I would be interesed in any suggestions on the following. I am using Fluent 12 beta release. Below is part of a udf to define a periodic boundary condition at the inlet. I've had this bc working in earlier versions of fluent. My problem concerns the initiaisation of a number arrays at the beginning of the routine.
The routine starts by intialising the arrays radexp, a0, a and b. The routine compiles, builds and loads ok using ms visual c++ 2008.
On intialising the flow field using the compute from 'inlet' the routine appears to read (from file) and write (to screen) the arrays radexp, a0, a and b correctly. However when I try to write a after reading b the elements of a become jumbled. This coding worked fine on versions of fluent prior to 6.4. Any help, suggestions greatly appreciated. I have tried reading and writing the arrays using pointers but I get the same result.
#include "udf.h"
#define M 128 #define N 13
DEFINE_PROFILE(inlet_velocity,thread,index) {
FILE *fp;
int i, j;
float radexp[25], a0[13], a[128][13], b[128][13];
real x[ND_ND];
face_t f;
real xcoord, ycoord, zcoord, radcfd;
fp = fopen("PBFFT12.txt","r");
for (i=1; i<N; i++)
fscanf(fp, "%f", &radexp[i]);
radexp[i] = radexp[i] * 0.001; //0.001 converts from mm to m
for (i=1; i<N; i++)
printf("%12.8f ", radexp[i]);
printf("\n");
for (i=1; i<N; i++)
fscanf(fp, "%f", &a0[i]);
for (i=1; i<N; i++)
printf("%12.8f ", a0[i]);
printf("\n");
for (j=1; j<M; j++)
for (i=1; i<N; i++)
fscanf(fp, "%f", &a[j][i]);
for (j=1; j<3; j++)
printf("%4d ", j);
for (i=1; i<N; i++)
printf("%12.8f ", a[j][i]);
printf("\n");
for (j=1; j<M; j++)
for (i=1; i<N; i++)
fscanf(fp, "%f", &b[j][i]);
for (j=1; j<M; j++)
printf("%4d ", j);
for (i=1; i<N; i++)
printf("%12.8f ", b[j][i]);
printf("\n");
for (j=1; j<M; j++)
printf("%4d ", j);
for (i=1; i<N; i++)
printf("\n");
fclose(fp);
begin_f_loop(f,thread) /* loops over all faces in the thread passed in the DEFINE macro argument */
// get the co-ordinates of tri-face centre
F_CENTROID(x,f,thread);
// set velocity at the tri-face centre
F_PROFILE(f,thread,index) = 0.02;
end_f_loop(f,thread) }
array in UDF Kamal FLUENT 1 November 7, 2013 01:15
Array problems Malachy FLUENT 2 March 5, 2012 15:11
can we initialize an array in UDF? blueberry Fluent UDF and Scheme Programming 2 April 14, 2009 12:00
Array declaration kdarc OpenFOAM Running, Solving & CFD 0 August 23, 2007 23:21
Increasing the F-array - Problem! Bernardo Santos Aflalo Phoenics 2 April 25, 2006 14:07
