March 24, 2009, 11:56 |
Particle melting during flight
Ellen
Rep Power: 16 |
I'm trying to model a problem where solid particles are injected into a continuous high-temperature flow, and then may melt during the flight. but if I select the inert particle in the DPM model, the solver would not include the latent heat term. so I'm wondering if any of you could kindly give me an idea how to include this particle melting part in udf, or if there's other way to do that? Thank you very much! Regards, Ellen |
March 24, 2009, 13:50 |
Allan Walsh
Rep Power: 17 |
One simplification would be to artificially increase the specific heat of your particle material so that as it heats to temperature T, the energy would be accounted for - sort of.
You could choose the built-in evaporation law and put in the appropriate latent heat. I generally advise people away from UDFs because it is a steep learning curve to get anything useful. However, if you are comfortable with them, it is certainly an option. |
March 24, 2009, 15:12 |
Ellen
Rep Power: 16 |
Thank you for your answering my question, Allan. But I'm still not sure how to do that. If I were to enable the evaporation law, I need to select "droplet" as my particle type, right? then I need to supply all the properties like vapor pressure, also I'm asked to provide the evaporating species. But my particles are solid, I don't have the required input. Could you please elaborate your method a little more? Thanks a lot.
Ellen |
Display Modes | |
Is UDF the only way to handle particle melting? | marq | FLUENT | 3 | February 23, 2008 02:48 |
Particle track files | Sankalp | CFX | 1 | August 26, 2004 00:25 |
the separated particle temperature in cyclone | mkuswadi | FLUENT | 0 | December 17, 2003 09:25 |
Iclude particle diameter effect in wall? | yueroo | FLUENT | 0 | April 14, 2001 04:56 |
Particle Trajectory calculation when particle hit | yueroo | FLUENT | 2 | February 28, 2001 05:26 |
