Obtaining x and y co-ordinates from mesh file
Old   September 23, 2009, 05:18
Default Obtaining x and y co-ordinates from mesh file
Marbig is on a distinguished road
Hey guys,
Im new to fluent and doing a simple problem of specifying a parabolic inlet velocity profile to a 2D -pipe.
Now to put my equation for my parabolic profile into the UDF I need to know the x values at the edges of the pipe. I was wondering how do I obtain the x and y values of a point in mesh file using fluent? When I right click on the very edge fluent spits out:
"Surface group = velocity-inlet-4, id = 2, name = velocity inlet -4"
Marbig is offline   Reply With Quote
Old   September 23, 2009, 17:48
audrich is on a distinguished road
Assuming you made the geometry yourself, and did so with some rationale, you could figure out the right coordinates using geometry and algebraic extrapolation of data you know (e.g. the surface is 100cm above the horizontal, y=100cm). It can be tedious but it's not difficult unless you were random in designing it.
audrich is offline   Reply With Quote
STL File - Mesh Surface Problems Harmeet FLUENT 8 May 13, 2010 21:59
Changing the grid on the same set-up Katya FLUENT 7 October 8, 2009 16:31
[OpenFOAM] Paraview command not found hardy ParaView 7 September 18, 2008 04:59
Compiling OpenFOAM13 on AMD64 with Redhat Enterprise mbeaudoin OpenFOAM Installation 20 June 17, 2008 06:43
PHI file structure Eugene Phoenics 9 November 2, 2001 22:00
