Open Channel Flow
Old   October 1, 2009, 02:01
Default Open Channel Flow
Sumit Sinha
forsumit is an unknown quantity at this point
I have gone through the forum archive but haven't found the answers for successful simulation of open channel flow. I hope some one has answers to my set of questions.
a) In Open Channel Flow, if I use pressure inlet, do I have to make two different inlets if the case being simulated is layer of air on top of water?
b) When I try to patch the VOF value of secondary phase as 1 using registers for the area occupied by the water and then export the volume-fraction of secondary phase, I only see the value 1 on the inlet side and not in the whole domain??
c) For the Open Channel Flow simulation, the density in the whole domain should vary between 1.225 kg/m3(air) to 998.2(kg/m3) right?
Any help will be greatly appreciated.
Thanks,
Sumit
forsumit is offline   Reply With Quote
Version 15 on Mac OS X gschaider OpenFOAM Installation 113 December 2, 2009 10:23
open channel problem (free surface) Andy Chen FLUENT 4 July 10, 2009 01:20
pressure outlet (open channel flow) Willem Brantegem Main CFD Forum 0 April 3, 2007 09:39
Open Channel flow Boundary khalid FLUENT 1 November 4, 2006 11:53
SIMPLE Scheme for open channel flow ao Main CFD Forum 0 April 6, 2004 16:21
