Quick help needed.....
Old   March 13, 2010, 11:31
Default Quick help needed.....
Gary Burns
Gary Burns is on a distinguished road
Ive got a box half filled with water.
It has a 1" Dia inlet at the bottom and a 1" Dia outlet at the top. (open to atomoshere)
The water is being sucked out of the inlet at -2.76 m/s.
im getting reversed flow at the outlet.
Ive tried increasing the outlet pipe length, but had no success with reversed flow problems.
any suggestions??
Thanks in advance
Gary Burns is offline   Reply With Quote
Old   March 14, 2010, 09:09
sega's Avatar
Sebastian Gatzka
sega is on a distinguished road
Originally Posted by Gary Burns View Post
any suggestions??
Tell us more about your (pressure) boundary conditions.
Schrödingers wife: "What did you do to the cat? It's half dead!"
sega is offline   Reply With Quote
Old   March 14, 2010, 10:17
Gary Burns
Im solving the problem using VOF.
inlet conditions - velocity = -2.97 m/s, Water volume fraction = 1
outlet-vent conditions - water backflow volume fraction = 0, mixture gauge pressure = 0
Im adapting a region and then patching in the water.
Im also solving the problem with water being pumped into the box at +0.9m/s.
This works fine.
Could the problem be that air is being sucked into the box through the outlet?? Which is what would happen as it needs to replace the water being sucked out of the inlet.
Thanks
Old   March 18, 2010, 12:57
sega's Avatar
Sebastian Gatzka
I'm not sure about the exact implementation of inlet and outlet boundary conditions, but does an inlet makes sense if there is something going out of the domain?
Implementation of QUICK scheme Romuald Skoda Main CFD Forum 11 November 6, 2017 21:20
QUICK Scheme mmahdinia OpenFOAM Running, Solving & CFD 3 December 9, 2009 16:30
Simulation diverges randomly QUICK santos OpenFOAM Running, Solving & CFD 4 August 18, 2006 17:39
a dissertation in ETD needed very much LiQiang Main CFD Forum 0 March 11, 2005 03:09
ENO, TVD, QUICK... I was wondering... Main CFD Forum 1 August 21, 2003 09:45
