Combustion with heat transfer and cooling
Old   June 16, 2010, 09:28
Default Combustion with heat transfer and cooling
Kamil Sobczak
KamilSobczak is on a distinguished road
Hello
I have question:
Is it possible to model methane/oxygen combustion (chemkin, pdf model) in a chamber and in the same time heat transfer to cooling fluid(incompressible, constant density) in outer channel in pressure based solver?
- species transport allows only one mixture (spark ignition is important), so after I import chemkin mechanism with reations and methane-liquid database I must add this fluid to the mixture and separation beetwen compressible gases and incompressible fluid isn't achieved.
- pdf model - calculates combustion from all species so maybe I can model incompressible coolant by secondary stream? But look-in tables are calculated after the species input
- vof model not allows combustion
- I don't know but maybe multiphase eulerian model is correct for my problem. Can I describe one phase like chemkin mixture and second one like liquid methane? But what will be interaction between phases?
Maybe some procedure exists in density based solver?
Any help and advice I will check if only you could give me some ideas
KamilSobczak is offline   Reply With Quote
combustion chamber, combustion modelling, conjugate heat transfer
Cooling Channel : Heat Transfer Gearb0x OpenFOAM Running, Solving & CFD 0 May 6, 2010 11:40
Heat transfer problem seojaho CFX 6 May 6, 2010 00:32
How can I increase Heat Transfer at Domain Interf? B.Simon CFX 3 October 28, 2008 18:53
UDF convective heat transfer correlations sarah FLUENT 0 March 29, 2007 09:52
regarding B.C. of Heat transfer problem Manoj Padmakarrao Raut Siemens 0 March 17, 2005 00:01
