Mixing Tank
Old   September 23, 2010, 10:56
Arrow Mixing Tank
Jawid
jawidnaik is on a distinguished road
Dear All
I am working on the CFD simulation of a mixing tank by using Fluent. The agitator used is the standard Rushtan Turbine. I am just a beginner to Fluent. I want to start with using Gambit to mesh the tank and the impeller.
Can any body send me the related links for tutorials or send me the tutorials on jawidnaik@gmail.com
Regards
Jawid
jawidnaik is offline   Reply With Quote
Old   September 26, 2010, 22:38
Mohsin Mukhtar
Mohsin is on a distinguished road
Hello
yes You can go to the following site and you can get all relavant information.
http://www.bakker.org/dartmouth06/engs150/
The following PDf would be relaly helpful to you.
http://www.bakker.org/cfm/publications/tn144.pdf
Regards
Mohsin
Mohsin is offline   Reply With Quote
Old   September 27, 2010, 01:48
Default Thanks Mohsin
Jawid
Than you Mohsin. These links are realy helpful.
I would like to mention that the basic problem i face is making geometry of a rushton turbine in gambit. I read from the links, i received from you, that the complex geometrise, like that of a rushtuon turbine, can be made in CAD and then imported to gambit or Fluent.
Is this software Auto CAD which mainly mechanical engineers use.?
Could you please tell me whether i can use gambit for making impeller geometry.?
If you don't mind, kindly give me your e-mail id by sending a test mail to jawidnaik@gmail.com
Khuda hafiz
Jawid
Old   September 27, 2010, 02:52
Mohsin Mukhtar
The following link is the GAMBIt tutorial. In this tutorial You can find tutorials related to impellers for drawing in GAMBIT. Go to tutorial 10 in the following link.
http://vincent.chapin.free.fr/Cours%...-tutorials.pdf
If you know CAD software (which mechanical engineers use for making designs) then you can make the design in CAD then u can import it in GAMBIt but still u need to use GAMBIt for mesh generation or you may need other softwares for mesh generation if you still dont want to use GAMBIt for mesh generation.
P.S. We can do all correspondence here. May be someone else can get benefit.
Mohsin
Old   September 27, 2010, 05:18
Jawid
Thanks Mohsin. I will go through the link and the tutorial as you suggested. will contact you latter.
Jawid
Old   October 5, 2010, 02:31
Jawid
Hi Mohsin, I have made the geometry of Tank and Rushton turbine in gambit, but i don't know how for i have gone correct.
Now i want to mesh the geometry. Before meshing it, I have to set different zones (like moving reference frame and stationary reference frame) for post analysis in Fluent. How this is being done in gambit, i don't know. kindly reply...
Regards
Jawid
Old   October 5, 2010, 02:39
Mohsin Mukhtar
After geomerty you have to do the following things:
1. Mesh the gemotry ...It is better to mesh your geomtry with hexahedral mesh volume elemants because it has got better quality.
2. then you have to check the quality of the mesh. If the quality (Equiangle and equiside skews are less than 0.85 then its ok otherwise you will face difficulties in convergence in fluent.
3. Then you export ypour mesh and in fluent You clikck on "check" which will check whether you have negative volumes and/or ur mesh is alrite etc.
4. Things like moving reference frames are decided in Fluent not in Gambit.
5. You have to first run the test tutorial on any model which is related to ur model which will give you sufficient practice. You can search on internet and/or the tutorials/materials which i sent you.
Good luck
Old   October 5, 2010, 02:49
Jawid
Thanks, i will do the same. Will contact you latter
Thanks
Jawid
Old   October 5, 2010, 14:03
anonymous
cfd_confuse is on a distinguished road
Hi Mohsin, i am also a beginner to fluent. i am also currently working on a 1m by 1m by 1m sq tank with an impeller. May i know how to go about setting the boundary conditions in fluent for the mixing tank?
cfd_confuse is offline   Reply With Quote
Old   October 5, 2010, 22:19
Mohsin Mukhtar
hello
You can see the pdfs which i gave to Mr jawaid above. It would help you out and also u can search CFD online website for more discussions on this topic.
P.S. I dont have experience of impeller geomtry but yes I am working on multiphase flows and mixing.
Good luck
Mohsin
Old   October 13, 2010, 03:49
Ahmed Mukhtar
ahmed.mukhtar89 is on a distinguished road
Thanks Mohsin. that was really informative
ahmed.mukhtar89 is offline   Reply With Quote
Old   October 13, 2010, 03:50
Ahmed Mukhtar
nice to see an informative platform like this... thanks
Sliding mesh setup for a mixing tank in Gambit nycera FLUENT 13 October 11, 2016 14:39
about the top of the mixing tank boh_tea FLUENT 7 August 21, 2010 03:58
Mass conservation problem in mixing tank multiphase simulation rockewan FLUENT 0 April 6, 2010 12:34
Modelling mixing tank using MRF Adi FLUENT 6 November 4, 2009 00:28
help about modeling A MIXING TANK hmasenger CFX 2 April 13, 2009 15:21
