How can I monitor pressure at a point?
Like Tree1Likes
  • 1 Post By wanghong
Old   March 31, 2006, 10:35
Default How can I monitor pressure at a point?
EA
Hello, I'm doing unsteady calculation and I want to monitor the pressure at a fixed point for each timestep. How can I do that in fluent? Thanks.
Old   March 31, 2006, 23:20
Default Re: How can I monitor pressure at a point?
wanghong
1 difine point:surface--point(input cordinates of point wanted) 2 solve--monitors--surface--fill your information to dialog table(to choice "pressure" under report...
soumitra2102 likes this.
Old   April 1, 2006, 02:53
EA
Thanks a lot man!
Old   April 5, 2006, 22:35
EA
Hello, I followed your steps but the static pressure is always 0. What should I choose for 'Report Type'? I chose 'Integral'. Thanks again.
Old   April 7, 2006, 11:44
Anindya
Choose area weighted average. Also save the values at every time step, not every iteration.
Old   April 8, 2006, 09:05
EA
Thank you!
Old   July 6, 2015, 01:22
freeday's Avatar
freeday
freeday is on a distinguished road
I want to monitor a pressure at a point which attached in moving wall. How can I make this point moving together with the wall?
freeday is offline   Reply With Quote
Old   March 4, 2016, 07:25
Halewijn Wayenberg
HalewijnW is on a distinguished road
I know this is an old topic, but I actually want to do the exact same thing as freeday but haven't been able to find a solution for it. Isn't there is simple way to move your monitor?
HalewijnW is offline   Reply With Quote
Old   September 26, 2016, 07:06
Default Hello All,
Rajendra Kumar
rajendra9424 is on a distinguished road
I have extracted the pressure as mentioned above but unfortunately pressure value is not matching with the experimental value with similar wave characteristics. More specifically, I am interesting in dynamic pressure.
Can anybody help me to find out the exact reason
Thank you in Advance!
rajendra9424 is offline   Reply With Quote
block-structured mesh for t-junction Robert@cfd ANSYS Meshing & Geometry 20 November 11, 2011 04:59
Problem with UDF compiling for kTkLW model Wantami FLUENT 0 July 18, 2011 05:11
[blockMesh] BlockMeshmergePatchPairs hjasak OpenFOAM Meshing & Mesh Conversion 11 August 15, 2008 07:36
[Gmsh] Gmsh and samplesurface touf OpenFOAM Meshing & Mesh Conversion 2 December 10, 2007 02:27
CFX4.3 -build analysis form Chie Min CFX 5 July 12, 2001 23:19
