three-phase separator
Old   July 14, 2003, 18:02
Default three-phase separator
Konstantinos Voulgaridis
Hi everybody,
I am trying to simulate a three phase flow in a oil/water/gas separator using VoF model. I managed to fill the volume of the separator with oil, water and gas at the desirable level. The boundary conditions are a velocity_inlet of the mixture and three outflows for each phase. However, when i run the simulation the computer is crashed or i receive a msg that a divergence detected in amg solver and the iterations stop. Do you know what kind of msg is that? Is there anybody who can see what i am doing wrong? Finally, are there any tutorials using VOF for more than 2 phases?
Thank you very much. I hope someone will reply to this and guide me. I appreciate it!
Old   July 15, 2003, 01:11
Default Re: three-phase separator
phd_y2k2001@yahoo.com
Konstantinos, I want to give you a series of suggestions, however, I will stop with a few:
1) If you are doing 3d, start from 2d 2) divergence could be bcos: i) Poor meshing ii) Time step too high ... 3) FLUENT vof demands patience I mean lot of patience 4) Never try steady state from the beginning
I am stopping here.
Old   July 15, 2003, 03:42
Thank you for your advice.
Old   July 15, 2003, 04:15
Do you mean that steady state is more difficult? The problem is that i have to run a steady state case for my separator.
Old   July 15, 2003, 05:58
U better run a steady state case and tell me whats the prob you are facing?
Old   July 15, 2003, 08:02
I really thnk you very much. This evening i will do some simulations but hey are very long. Thank you again
Old   July 16, 2003, 01:26
Hi Dr,
I have done some steady state simulations but it seems that the phases dont want to be separated from the mixture even if i use the gravity in the Operating conditions. Do you know if i should assign gravity settling forces in each face? Thank you in advance
Konstantinos
Old   July 8, 2011, 09:27
wibi ario
sincity is on a distinguished road
hi..i want to simulating like what you've simulated...can you give me a clue, please
sincity is offline   Reply With Quote
alphaEqn.H in twoPhaseEulerFoam cheng1988sjtu OpenFOAM Bugs 15 May 1, 2016 16:12
how to make a good three phase separator model wibi ario FLUENT 0 November 5, 2010 22:38
CFD simulation of Three phase separator tushar393 Main CFD Forum 3 December 22, 2009 22:41
retrieve data from the Lagrangian phase in a cyclone separator HugoRodrigues Siemens 0 April 16, 2009 04:21
compressible two phase flow in CFX4.4 youngan CFX 0 July 1, 2003 23:32
