Rotor67 planes along blade in streamwise direction
Old   July 26, 2011, 09:48
Default Rotor67 planes along blade in streamwise direction
Preetham
preetham108 is on a distinguished road
Hello Folks,
This is with regard to my project on Rotor67, I needed some surfaces, within the fluid-domain as shown in the attached image.
If you could help me with settings within fluent/cfx, to do the same . I need them to periodic like the blade surfaces.
The attached image is of NACA rotor. I need similar surfaces on Rotor67.
Is it possible to have surfaces through the blade and the endwall recirculation passage as well ?
Thank you,
Pai
preetham108 is offline   Reply With Quote
Calculating lift force of a wind turbine blade problem LittleBart CFX 4 June 29, 2011 02:33
Rotating blade in circular/square vessel (Salome+OpenFoam) voingiappone OpenFOAM 0 May 19, 2011 11:38
Blade tip with tetra/prism method vinc ANSYS Meshing & Geometry 0 May 17, 2011 15:22
stress analysis of a rotating beam(wind blade) Cheyannne ANSYS 0 October 19, 2009 17:06
Meshing a 3D, tapered and twisted blade with Gambit-TGrid teskio ANSYS Meshing & Geometry 0 July 3, 2009 10:36
