November 2, 2011, 03:42 |
2 phase heat transfer
Alex Christantho
Rep Power: 16 |
I want to study about the phase change due to the heat added into the system.
My system is a solid rectangular (materials : wood) which has a hollow sphere inside. The sphere is filled with the phase-change materials (paraffin, phase-change temperature is between 295-300 K). The initial temperature is 273 K so the paraffin is still in solid phase. then the heat flux is given on one side of the rectangular wood, which the other sides are insulated. I want to know the temperature contour and the liquid fraction for every seconds of simulation (unsteady conditions) but I have no idea how to setup the Fluent, specially to set these two materials (paraffin and wood). Should I use solidification/melting and multiphase (2 phase Eulerian mode) options or use the other one? could anybody help me to develop this case? Thank you. |
microchannel two phase flow with heat transfer | mkj | Main CFD Forum | 2 | September 27, 2011 21:49 |
MRF and Heat transfer calculation | Susan YU | FLUENT | 0 | June 2, 2010 08:46 |
CFX Heat Transfer | RJamison | CFX | 0 | July 24, 2008 12:11 |
Heat transfer coefficient for dispersed phase | Julie | Siemens | 4 | October 30, 2004 14:26 |
