Fluent Postprocessing - NEU!
Like Tree1Likes
  • 1 Post By swetkyz
Old   November 3, 2011, 07:04
Post Fluent Postprocessing - NEU!
Stefanos Katifeoglou
stefanos is on a distinguished road
Good evening, dear people,
I have solved with FLUENT a very long 3d pipe -for some reason- of 10^6 elements.
I would like to export a "xy data" file with 1 column for dyn-pressures and 1 for velocities, in order to further integrate the corresponding values on several cross-sections.
Could anybody introduce me a way to avoid a full-domain data file creation of such a hugh size? More specifically, could FLUENT provide me "jumping" on individual cross-sections of my interest and export only those values in a file?
Thank you in advance!
stefanos is offline   Reply With Quote
Old   November 5, 2011, 09:41
Zachariah Swetky
swetkyz is on a distinguished road
Stefanos,
For the "jumping" issue, you can create surfaces on cross sections of interest using Define>Surface (I believe). It is very straightforward to define a plane using three points. Once the surfaces are defined and named, you can simply select them for the xy plotting or use them for any other reports or monitors.
-Zachariah
stefanos likes this.
swetkyz is offline   Reply With Quote
Old   November 7, 2011, 05:07
Thanks you, Mr. Zachariah!
datafile, fluent, postprocessing
Two questions on Fluent UDF Steven Fluent UDF and Scheme Programming 7 March 23, 2018 03:22
fluent parallel problem in win7 x64 system dunga82 FLUENT 8 April 19, 2012 20:23
What the differences flow equation of Fluent 6.3 and Fluent 12.1 opehterinar81 FLUENT 0 August 19, 2011 11:55
Master node in parallel computing only distirubtion syadgar FLUENT 1 September 8, 2009 16:41
fluent journal files - speedup your postprocessing warlock FLUENT 0 March 8, 2006 23:36
