Inlet velocity mismatch in low microchannel
Old   December 10, 2011, 01:43
Default Inlet velocity mismatch in low microchannel
deewakar
alligngr8 is on a distinguished road
Hello everyone,
I am trying to simulate flow in rectangular micro channel of dimension (10 X 10 um). I gave the inlet velocity as its criteria and applied uniform flux on its wall.
However I am facing some issues reg. that.
[my flow is along 'z' direction, width along 'x' and height along 'y']
Firstly, I applied a uniform velocity 10m/s at the inlet. But when I tried to plot it velocity vs height at the inlet, fluent showed correct velocity plrofile for y up-to 9.5 micron.However, for 9.5 micron to 10 micron height there was linear variation.(where as as expected it should have been 10 through out,as inlet velocity is constant at 10).
Is it that fluent is not fit for such small dimension. ??
Or is it that it has included contraction effects etc. If so , how to do away with them.
Similarly there was problem with flux applied.I applied 50,000 W/m2. But it was showing 1.2e6 (considerably more than what I applied) in small region after which it showed normal expected behavior.
Pls guide.
thanks
alligngr8 is offline   Reply With Quote
Steady pipe flow mean velocity higher than inlet velocity anita OpenFOAM Running, Solving & CFD 7 September 25, 2012 05:35
FSI- Pipe- uniform velocity profile inlet Absy Main CFD Forum 0 April 6, 2010 03:01
inlet velocity BC ahsan FLUENT 3 July 22, 2009 04:17
Pressure Inlet Velocity prapanj OpenFOAM 11 June 23, 2009 11:15
Variables Definition in CFX Solver 5.6 R P CFX 2 October 26, 2004 02:13
