Help - Simple Time-Temp Modelling - 2D Cylinder
Old   February 27, 2012, 07:26
Default Help - Simple Time-Temp Modelling - 2D Cylinder
Tatey is on a distinguished road
I am currently trying to model an experiment I recently carried out to investigate cross flow heat exchanger design. I have decided to start off in 2D using fluent to keep things simple.
After reading through the forum I have gained a lot of knowledge in fluent and have sucessfully managed to model a 2d cylinder in a turbulent flow.
However the experiment used a pre heated copper element which was placed in the air flow and the temperature decay was then logged. I am trying to replicate this on fluent however I am unsure on a few things. Mainly how to get fluent to assume that the cylinder has a uniform temperature throughout its thickness (the same assumption used in the experiment) and for it to give me a time temperature graph of the cylinder. The starting temperature of the cylinder is 88.5°C and final temperature is equal to the ambient air temperature (usually 20°C). I am also struggling on getting fluent to have an initial starting temperature of 88.5°C and for this temperature to decay with time.
Any help in this would be much appreciated.
Tatey is offline   Reply With Quote
Physical Reason for stability of Implicit Schemes? radhakrishnan Main CFD Forum 26 October 3, 2023 22:05
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 15:33
2D cylinder modelling pieizquierdo (miguel) FLUENT 0 January 10, 2005 16:59
unsteady calcs in FLUENT Sanjay Padhiar Main CFD Forum 1 March 31, 1999 12:32
