[HELP] mass fraction in multi-component granular flow?
Like Tree2Likes
  • 1 Post By doronzo
  • 1 Post By doronzo
Old   March 15, 2012, 09:14
Question [HELP] mass fraction in multi-component granular flow?
Li Huang
lihuang is on a distinguished road
Hi all,
I am trying out FLUENT Mixture multiphase model to solve multi-component granular flow. I have two velocity inlets and one pressure outlet. The fluid is air, and the secondary phases are multi-component particles of different sizes. At these two inlets, the mass fraction of each component (species) is different. For example, (0.2A+0.8B) at inlet 1 and (0.5A+0.5B) at inlet 2. Even with no chemical reaction or mass transfer between phases, it seems the mass fractions of secondary phases are not solved by FLUENT. Any ideas?
BTW, I tried Eulerian model. It does solve for mass fraction of the secondary granular phases, but it did not converge well. And it takes much longer time so I dont want to consider Eulerian model for now (unless absolutely necessary).
lihuang is offline   Reply With Quote
Old   March 15, 2012, 11:36
Domenico
doronzo is on a distinguished road
hi
how big are the particles? how concentrated is the initial flow? do the particles enter the domain in (quasi) mechanical equilibrium?
regards
doronzo is offline   Reply With Quote
Old   March 15, 2012, 11:56
Li Huang
Originally Posted by doronzo View Post
hi
regards
Thanks for your reply.
Particles are very small with diameters in the range of nm to micrometers. The volume fraction of particles from inlet is around 1E-10. But what does it mean by being in mechanical equilibrium? How do I specify it?
Old   March 15, 2012, 12:05
Domenico
...if the particles enter the domain with the same, or similar, velocity.
why not to use the DPM (discrete phase model)? has your grid a high resolution?
regards
Old   March 15, 2012, 12:20
Li Huang
regards
particles are entering with the same velocity. I am not using DPM because I am having a great number of small particles. I am not interested in the actual tracks of each particles but the volume fraction and composition of particles far away from the inlets. In the future I have to expand my open domain to about several hundred meters. When I read the introductions to FLUENT multiphase model, I figured to go with the mixture model.
I dont have a very high resolution grid right now. But I plan to do so.
Old   March 15, 2012, 12:43
Domenico
it indeed depends on the goals, but in general a particle concentration like that isn't high. also, the number of tracked particles depends a lot on the grid, because they are treated as cluster of particles, so I don't expect you would have a prohibitive number of trajectories.
in a first approximation you could consider your small particles as fully coupled to the fluid, and treat the mixture as multispecies (Fluent multispecies model), i.e. air (species 1) + pseudofluid (species 2, with its properties modified by the particles, e.g. increased density and viscosity; Marble 1970, Annu. Rev. Fluid Mech.).
in this second case, you could directly follow the species mass fraction, but of course you cannot have the particles leave the fluid transport system
lihuang likes this.
Old   March 15, 2012, 13:03
Li Huang
Thanks. This is definitely a good approach, but I need to sort it out. For example, I do need to remove some particles from the system due to deposition. It physically does happen during the transport over several hundred meters.
As I have already done quite some work based on the mixture model, I would like to figure out how to solve mass fraction of the secondary granular phases. I don't mind creating UDFs either.
Old   March 15, 2012, 13:37
Domenico
I'm not too much familiar with the mixture model, but I think it's basically similar to a pseudofluid approach, with the difference it solves for the relative velocities, as well as the volume fraction of the secondary phase. This is done with some algebric expressions for the velocities, and a volume fraction equation for the secondary phase
lihuang likes this.
Old   March 16, 2012, 09:54
Li Huang
regards
I checked the FLUENT theory guide again, and it says DPM is not compatible with multiphase species transport.
Old   March 26, 2012, 14:59
Li Huang
I found what causes this is probably i am using too low volume concentration of the secondary phase. In my case I have to deal with volume fractions as low as 1e-20 or lower. But it seems FLUENT double precision solver works fine on mass fraction for secondary phase volume fractions greater then 1e-08. Anything smaller than that becomes 0.
Any idea to work around it?
Error message: Insufficient Catalogue Size Paresh Jain CFX 32 February 3, 2021 03:37
Mass flow rate: calculation v/s computation beguxa FLUENT 5 December 2, 2018 21:02
Convergence problem with target mass flow rate ADL FLUENT 2 May 29, 2012 21:11
Difference between Volume Fraction and Mass Fraction in CEL foo7 CFX 0 September 21, 2011 08:45
Mass flow rate through each cell Babakjingo Main CFD Forum 0 August 21, 2011 03:18
