Home > Forums > General Forums > Lounge
how to have less characters in Ubuntu password?
Like Tree1Likes
  • 1 Post By wyldckat
Old   December 12, 2013, 08:39
Default how to have less characters in Ubuntu password?
immortality's Avatar
Ehsan
immortality is on a distinguished road
Ubuntu doesn't accept short passwords,but the pass is requested for very works that makes it boring to type a long password again and again.
what's the solution? it seems a smaller pass is better than not having a pass at all.
how can have smaller pass or maybe delete it totally if needed?
Injustice Anywhere is a Threat for Justice Everywhere.Martin Luther King.
To Be or Not To Be,Thats the Question!
The Only Stupid Question Is the One that Goes Unasked.
immortality is offline   Reply With Quote
Old   December 15, 2013, 10:03
Retired Super Moderator
Bruno Santos
Hi Ehsan,
The smaller the password, the more likely you'll have another computer-related bad time once again in the near future.
Please be more specific: in which situations is it asking you repeatedly for a password?
Possibly the problem is more related to the way you're using Ubuntu, than it is the length of the password.
Best regards,
Bruno
Old   December 15, 2013, 10:38
Ehsan
Hi Bruno,
I use it commonly,when it becomes on and want to install things or want to use sudo,
in 11.10 I had used only 3 characters but in 12.04 it doesn't accept small passwords.have they changed this?
Old   December 15, 2013, 11:21
Bruno Santos
  • If you need to use sudo, always use the same terminal window. It will allow you to use sudo for at least 15 minutes, without asking for the password again.
  • Logging in can be done automatically for you, if you are the only user.
  • The screen saver can be configured to not lock the screen with a password.
I'm starting to see how you so easily broke the file system and lost files several weeks ago, without even registering in your mind what happened. With a 3 character password, it was too easy for you to run a command with super-user powers, simply because it didn't work with normal user powers.
It didn't give you enough time to properly think about what you were going to do and if it was going to be safe or not. Result: in less than a second, all went down the drain
And now you seem to be unconsciously planning to lay the same trap for yourself again...
immortality likes this.
ANSYS APDL in Ubuntu 12.04 chinese characters efirvida ANSYS 3 November 26, 2013 04:59
Ansys 13 - License problem on Ubuntu MarTar ANSYS 4 February 3, 2012 02:13
How to Install OpenFOAM on 64 Ubuntu 9.04 hansel OpenFOAM Installation 62 March 19, 2010 14:43
OpenFOAM on non-English Ubuntu distribution fabian_roesler OpenFOAM 3 January 11, 2010 07:16
Adventure of fisrst openfoam installation on Ubuntu 710 jussi OpenFOAM Installation 0 April 24, 2008 14:25
