Dissipative scheme
Old   December 20, 2005, 09:15
Default Dissipative scheme
P.Cooke
hello all. i am a little confused and wondered if someone can point me in the right direction.
1) firstly, is the following statement true.... image a turbulent jet flow. if we over predict the dissipation of turbulent kinetic energy, then there will be less enegy and motion in the eddies to mix the jet. therefore if we DO over predict the dissipation of turbulent kinetic energy the modelled jet will mix and spread less. are these statements true???
2) secondly, based on the first points, if in solving the navier stokes equations we use say an upwind scheme, i.e. a dissiaptive scheme, what effects does this have on the same jet simulation. i would have thought the dissipation would again damp fluctuations and therefore cause less mixing? but also the upwind scheme will 'smear' the solution on the mesh and therefore 'apparently show more mixing'. what are the effects of the upwind scheme on a spreading jet and how do these effects differ from the ones discussed in the first point i made.
any comments would be great as i am (as you may tell) a little confused.
how to understand high resolution scheme and high order scheme iilw1314 Main CFD Forum 7 April 12, 2022 12:29
Implementation of QUICK scheme Romuald Skoda Main CFD Forum 11 November 6, 2017 21:20
AUSM scheme ? Central Scheme boling Main CFD Forum 7 January 7, 2016 02:41
2nd order upwind scheme (Fluent and CFX) Far FLUENT 0 May 22, 2011 01:50
extrapolation in MUSCL scheme Chandra Main CFD Forum 6 February 14, 2007 11:21
