Under Relaxation factor
Old   August 21, 2012, 07:06
Default Under Relaxation factor
Konstantinos
kostas is on a distinguished road
i am implementing an under-relaxation scheme in an incompressible code. The code firstly solves for an auxilliary velocity, which does not take into account pressure effects. Then, it adds the influence of pressure through the incompressibility condition and corrects the velocity field. I am applying the method used in Peric book, where he mentions that under-relaxation modifications are done in the final linear system Ax=b, where x is the unknown(velocity). Does this linear system involve pressure term also?
What i have done, is that i implemented under-relaxation in the linear system for the auxilliary velocity. Is it correct? and how can i apply this method to the corrected velocity?through pressure?
I have implemented in also in scalar equations, which i think is straightforward.
kostas is offline   Reply With Quote
Under relaxation factor for external coupling dhxlxz CFX 10 August 11, 2015 20:52
under relaxation factor and the steady state jing113cn FLUENT 0 November 2, 2009 12:13
Relaxation factor Benzaa Main CFD Forum 1 August 18, 2009 07:27
Question on adjusting relaxation factor CFD Rookie Main CFD Forum 3 January 26, 2004 14:37
Relaxation factor Moon Siemens 1 June 13, 2003 11:13
