Implementation of QUICK scheme
Like Tree2Likes
  • 2 Post By Dr. Hrvoje Jasak
Old   January 20, 2000, 03:02
Default Implementation of QUICK scheme
Romuald Skoda
Hallo,
I am implementing a QUICK convection scheme into a 2d pressure-correction (SIMPLE-like) RANS code for non-orthogonal grids. The code in formulated in cartesian co-ordinates. The time discretisation is fully-implicit. I intend to scale-up the code to 3D later.
1) In the open literature I found the QUICK formulation for non-uniform grids, not for non-orthogonal and body-fitted grids. So firstly I implemted the scheme proposed for non-uniform but orthogonal grids. Is there an advice or a reference what could be done better with non-orthogonal grids?
2) I neglected the transverse curvature terms. Does someone know some references about the implementation of the QUICK scheme including the transverse curvature contribution and/or its performance for highly convective / turbulent flow?
3) I suppose that the scheme works equally for steady-state and transient solutions, if I use an implicit time discretisation. Am I right? What about an explicit time-marching scheme? I intend to implement an explicit pressure-correction scheme. Can I expect that I do not have to modify the interpolation scheme?
Thanks a lot in advance!
Romuald
Old   January 20, 2000, 04:16
Default Re: Implementation of QUICK scheme
Dr. Hrvoje Jasak
You haven't chosen my favourite scheme (you'll have boundedness problems later!), but I think I can help:
1) QUICK for non-uniform grids in fine and you don't need to modify it any further. All 'curvilinear' or 'non-orthogonal' corrections are unnecessary - they will just increase your computational molecule but won't give you any additional accuracy.
2) You did fine - forget about curvature.
3) The scheme is fine. You'll have to under-relax the system for pressure correction (as does everybody else); this kind of stuff is well tested and publicised with both SIMPLE and PISO.
The only trouble you can expect (to my knowledge is):
a) boundaries need special treatment as there's no "far upwind" node. b) the scheme is unbounded, i.e. for a variable which is laways positive (e.g. T or k) you can get negative face values, which causes trouble. However, there's a bunch of NVD-modifications to QUICK (called SMART of SHARP, I'm not quite sure) - you will need those when you start convecting scalars c) QUICK is a real bitch to implement on unstructured meshes, as you loose the directions. But that's another subject.....
Hrv
Old   January 20, 2000, 05:39
Romuald Skoda
Thank you very much for your quite encouraging advice. Actually, I know about the boundedness problem and intend to implement the SMART scheme, which includes the QUICK scheme. May I ask what is your favourite scheme you mentioned, which does not seem to suffer from boundedness problems, even if no flux limiter is used?
Thanks Romuald
Old   January 20, 2000, 08:28
Dr. Hrvoje Jasak
Unfortunately, there's no linear scheme other than Upwind differencing that does not suffer from unboundedness, so I'm afraid that you'll always need a limiter. I have developed a scheme called Gamma (Int. J. Numer. Meth. Fluids,31:431-449, 1999) and it's been extensively tested on a lot of stuff, from combustion to two-phase and free surface flows. It is an NVD (limited!) scheme and its main advantages are i) it works on arbitrarily unstructured meshes (no need for "far upwind node") ii) compact support (blends UD and CD) iii) no time-step dependency and iv) (and most important) it's the simplest I could do! However, (I don't know the aim of your project), I think you made a decent choice, unless you ultimately want to make your code arbitrarily unstructured, so I think you can happily just QUICK away!
Have fun,
Hrv
1/153 and breznak like this.
Old   January 28, 2000, 19:43
Seok Ki Choi
Hi Dr.Hrvoje Jasak
You mentioned that you have tested your Gamma scheme on a lot of practical flow problems. How was accuracy of your Gamma scheme for practical flow calculations when compared with QUICK, SMART, HLPA or SOUCUP schemes ?
Seok Ki Choi
Old   March 22, 2009, 23:18
Prakash Ayappan
technocrat.prakash is on a distinguished road
Originally Posted by Romuald Skoda
;7215
Hallo,
Romuald
Certainly, this is not a advice for you. Actual purpose is I need the open literature for the Quick Scheme. Can you send me to my mail technocrat.prakash@gmail.com
technocrat.prakash is offline   Reply With Quote
Old   March 23, 2009, 03:03
ztdep's Avatar
p ding
ztdep is on a distinguished road
Send a message via Yahoo to ztdep Send a message via Skype™ to ztdep
Originally Posted by Dr. Hrvoje Jasak
;7220
Have fun,
Hrv
Dear friends:
Could you please send me your paper about your Gamma scheme, i can not find it.
Regards
ztdep is offline   Reply With Quote
Old   March 23, 2009, 03:11
Default Your paper
Hochola is on a distinguished road
Hi, if it's possible I would also like to get a copy of your paper about the GAMMA scheme. Could you e-mail it to me, if it's not a problem.
Thank you
Hochola is offline   Reply With Quote
Old   July 14, 2010, 15:10
Mieszko Młody
ziemowitzima is on a distinguished road
Dear Dr HJ
You wrote that QUICK scheme is unbounded, but in OF-1.6 UserGuide in:
Table 4.10: Behaviour of interpolation schemes used in divSchemes.
It is written that QUICK is bounded.
could you tell me which statment is correct ?
Best,
ZM
ziemowitzima is offline   Reply With Quote
Old   August 3, 2010, 11:50
Nick Gardiner
NickG is on a distinguished road
There's a link to Prof.(!) Jasak's PhD at
http://openfoamwiki.net/index.php/IcoFoam
NickG is offline   Reply With Quote
Old   August 3, 2010, 12:23
Mieszko Młody
Thank You !
It is really great works !
Old   November 6, 2017, 21:20
Francisco Angel
francisco.angel is on a distinguished road
Quick author recommends quickest scheme for unsteady problems, see "a stable and accurate convective modelling procedure based on quadratic upstream interpolation" by B.P. Leonard.
francisco.angel is offline   Reply With Quote
2nd order upwind and QUICK scheme Wiroon Main CFD Forum 19 September 17, 2019 03:47
Upwind, central, QUICK scheme for Re~10000 quarkz Main CFD Forum 4 June 23, 2011 15:04
QUICK Scheme mmahdinia OpenFOAM Running, Solving & CFD 3 December 9, 2009 16:30
FEM Implementation of pressure-correction scheme Markus Main CFD Forum 4 January 6, 2007 01:53
QUICK scheme kim FLUENT 1 August 29, 2002 10:16
